77 cj5 304 3 speed
another project, it needs your home!
900$
needs a wiring harness, headlights to tail lights. Very solid frame, body is good enough to use. 304 w/ alum. intake and a quadrajunk. it did smoke when i ran it. 3 speed stick, dana 20 to a model 20. dash is there, just removed to pull the scrap harness out. it does have factory tach and clock option.
J does this still run?
yeah, it’ll run, idle, rev fine. only some smoke. i actually never had it running long enouh to see if warming it up would clear it out! i did change the plugs and it helped a lot.
