9/16-18 Tap
I only need to tap one hole and I can bring the part to you.
LMK ASAP, thanks.
let me check tomorrow, pretty sure we have an Irwin SAE set @ the shop from Jager. you’re more than welcome to use it
I only have up to 1/2 taps in my Deluxe set.
well then, i have a 14x1.5mm tap and die which is about the same size, would that get the job done?
I have a 9/16-12
I will look to see
