91 CRX Si build
my 91 crx si b16… Under Consturction…
Subscribed!
how about some info…?
+1
ooooohhhhhh i kinda like it! more pics/details! and keep it clean and sleeper status, looks like its got potential
im gonna post more tonight wen i get outta work… i just wanted to get some pics of her up first… but more info comin soon./…
sleeper is my plan… so far… just nice paint and thats it… no body mods…
ok so here is the list of goodies… so far… this is when i got the car … not includin any of my new trbo setup or anything special…
B16A obd0 motor
Y1 c/r trans
Hasport billet mounts
Skunk2 cams stage 1
Skunk2 adj. cam gears
DC sports header
Tanabe super spec rare medallion exhaust
Gutted cat-stainless steel cat back
KYB AGX struts
APC coilovers
Falken 17" wheels
PWO ECU
Mugen ecu chip
GSR short shifter
Autometer 5" tach
Shift light
Air/fuel ratio guage
Brembo slotted cross drilled rotors
Axis semi meallic pads
9.3 silicon plug wires
Billet oil cap
EXedy stage 1 clutch
Heavy duty pressure plate
organic disc
9lb. chrome moly flywheel
Rear deck cover
misc. energy susp. bushings
motor has been reringed and new valve seals
carbon fiber plug wire cover
Ry-wire vtec custom built harness
Looking good. What kind of turbo set up are you going with
right now i have a dual ball bearing 30r… ill run 'er wit that till she blows and then ill build the block… my head is already done…
im just waiting for brooks to backdoor my intercooler… and awaiting my full race traction bar… then new paint and off to synapse to be tuned… it’ll be a late start for me this yr… that or an early start for nxt yr
lol its mid september i’d call that late. GL with it though
def love crx’s! somebody else has one i wanna see done i wont name any names but :ponder
it starts with vovc and ends with andr and has an h in the middle :thumbup
I don’t think it has moved out of the corner of his garage in years.
Not a bad start. I just don’t like the 5" tach and air/fuel gauges are useless.
*Goes and blows dust off and takes the cover off to check
Yep still there. Now it’s got a random build block sitting next to it too. :ponder
Either way, good luck! I’m interested in seeing it get done.
ya not by choice… they were in it when i bought the car… only the tach is hooked up now…
ya it should be done within a few wks… the motor atleast…
good luck with the build, keep it updated :thumbup
5" tach :rofl
but how is the A/F gauge useless? If you dumped money into a build motor, I would want to know if I am lean for becasue I clogged a fuel filter, or some dumb shit. Or pig ass rich and rish washing the cyclinder walls becasue of a big boost leak or something like that.
Most air/fuel gauges people have are just the ones that changes from red to green. There pointless because most people don’t know how to correct the problem anyways.
Just get a wideband and call it a day.
