93 civic hatch rear-disc conversion
ive got a 1993 civic hatch (currently looking for motor/manual tranny swap) and its got rear drums, was wondering how difficult it is/what it entails to swap to rear discs, and if anyone had the materials required.
I didi the swap a while back. The should give you a good idea how to do it and what you need.
http://shift518.gom-host.com/showthread.php?t=1330&highlight=reckone&page=4
very easy swap everything bolts right up from the 94-01 integra also easiest rear disks to find and dont worry about swap the the proportioning valve the stock one works alot better than the si 50/50
I have everything you need, prop valve, ebrake cables, trailing arms with everything still on them. Shoot me a PM if your interested.
…I don’t know about the 50/50 prop valve everyone has always said its a huge no-no to use the wrong one…
My breaks work great with the stock prop valve, but I do have type-r brakes in the front.
If you happen to want to get rid of the ebrake cables lmk, I still need one.
