FS Item(s) Description:
fs or ft
body 18* ***km
jdm front end
wings west side skirts
wings west rear lip
painted 08 no rust also no water leaks like 70% of the dc out there
itr spoiler
J’S carbon fiber canards
Carbon Fiber hood
8k hids
98+ red taillights
inside
gsr leather door panels dash
gsr Leather Arm Rest
itr USDM cluster
nrg one piece fiberglass all black seats 12lbs(if we are trading we keep are own seats)
momo corse steering wheel
silver sparco 4 point harnesses
4 point mild steel mig welded 1/2 car cage (comes with door bars)
skunk2 short shifter
itr shift knob
battery in trunk
oil pressure gauge
volt gauge
engine 2 options
option 1
17*km b18b1 stock motor dyno at 125.7whp and 114 torque lol just so u know it helthy
6"-3" blox velocity stack
new exedy oem clutch less then 1000km
7.5lb fidanza flywheel
dc 4-1 header 2.5"
vibrant 3" ss exhaust
walbro 255 fuel pump
option 2
fully built not even 1000km
head
b16 head
p&P
precision injectors
aem fuel rail
aem fuel pressure regulator
golden eagle fpr relocator
itr valve cover
skunk2 pro 3+ cams
skunk2 pro valve springs
skunk2 pro ti retainers
skunk2 valves
skunk2 cam gears
edelbrock victor x intake manifold
edelbrock victor x throttle body 70mm
edelbrock victor x 70mm Spacer/Adapter Kit
edelbrock tps
hondata intake manifold gasket
td-44u dizzy
blox velocity stack 6"-4"-3" pipe
cometic head gasket
block
gsr block
84.5mm benson sleeved block stamped on block
cp pistons 12.1
itr eagle rods
itr crank
bored out arp main studs
all new oem bairings
itr water pump
itr oil pump
greddy timing belt
itr pulley
hasport motor mounts
mishimoto rad
mishimoto slim fan
tranny
sir tranny
Fidanza flywheel 7.5lb
bully stage 4 clutch
engine needs a tune has not been tuned sence it was built this motor with a good tuner should make 220+whp
suspension
omni power lca
nex coilovers 12-6k
front strut bar
rear strut bar
rear lower tie bar
come with extra
front bumper and oem lip cut out (track bumper)
rear hatch red no spoiler
stock jdm hood
bad
front bumper has scufs and it was painted in 08 and black loves to have swirl marks from the microfiber drying (needs a detail to look fresh again)
the engine bay was painted but it has chipping paint
car is not on the road so u will need to come test drive it
Asking Price:
trade for eg ek hb NO RUST and floor must be solid NO leaking fire wall
also depending on trade parts will be removed
with b18b1 4500 firm no rims or seats
with 2L motor 9500firm
kitchener
Contact:
pm
the teg is on jack stands due to police inspection on my eg so i needed the coilovers and also the b18b is in the eg. so look at the teg and tes drive the civic and if we agree on something then it will all Be swapped over in a day
ls b18b
built engine
