99 Grand Am 3.4L Knock Sensor Issue.
OK, this one has me stumped. I picked up a 1999 Grand Am (My first mistake I know) It had a check engine light for the knock sensor (Low Voltage). I figure a quick change of the knock sensor and all would be well.
First thing I did was swap the sensor for a new one and clear the codes, next day the light came back on.
Next I used a multi-meter and tested the sensor and it test out as good, I figure there must be a break in the line somewhere so I replaced the line from the knock sensor to the PCM. I cleared the light, came back the next day.
I then did some research and found that the knock sensor output on the PCM could be bad, I replaced the PCM. Now the check engine light is back.
Now that I have a new PCM, New Sensor, and a New Wire I am stumped. Any ideas?
You should check out www.gaownersclub.com for all the info you need on the 3400
idk how it for grand ams but for my neon, the knock sensor was dependent on how it was torqued down
