Will it work?
Yes just block off the ABS line in the master.
you’ve got it backwards, the ABS unit uses 2 lines and splits them at the ABS unit. The nonABS uses 3 lines and the rears split at a T fitting.
you must remove teh plug from the 1 front line and insert a flare fitting for the brake line to mate to. If you just remove the plug the line won’t seat properly and the system will leak from there.
This is the process for Z32 MBC install into nonABS S13…
what does the Flare exactly look like and can I get it at CT?
the opposite of the flare on the brake line… Look inside the the other openings and you should see the difference.
Probably not at CT…
I see, will this split into 2 then so I can screw both ends in??
bring that it is Missing a line?
I tried looking for pics
huh? this = vague pronoun
bring that is missing a line??? huh
haha a sorry i am running out of work,
thanks
