Well, I have a set of these:
http://cgi.ebay.ca/SILVIA-240SX-S14-1995-1998-REAR-UPPER-CAMBER-ARMS-ARM_W0QQitemZ8022393043QQcategoryZ33581QQrdZ1QQcmdZViewItem
And I was wondering if you guys think there would be much difference between that style and this one:
http://cgi.ebay.ca/Rear-Upper-Camber-Arms-RUCA-89-94-Nissan-240SX-S13_W0QQitemZ8022204907QQcategoryZ33581QQrdZ1QQcmdZViewItem
Do you think there would be a difference in strength or would the first one with one “arm” twist or move around more? I allready have my suspension out of the car, so adding these wouldn’t be a hassle no matter what design I went with.
For the record I don’t have that exact one, just the same style. I don’t know where it came from, my buddy bought it and then blew his engine, so he didn’t need these anymore!
RS13
December 15, 2005, 2:41pm
2
1st one is for an S14
2nd for an S13.
Well, I noticed that the first one says it’s for a S14, but does that mean it is only for a S14?? Are the S14 and S13 ones different? Or will that one not work for a S13?
Take a look at these guys http://www.splparts.com/ I got a set of tension rods off them. I don’t think you can beat them for the price.
RS13
December 15, 2005, 4:45pm
5
Yes they are different and will not interchange. S14’s hit the coil on a S13
HAHA!! Well someone screwed my buddy around on those! Glad I didn’t pay for them!
Anyone need some S14 adjustable camber arms?
RS13
December 15, 2005, 5:13pm
7
opps forgot to mention Bings.ca has one design that does both but i believe theya re different than the ones on ebay.
Well, does anyone know if these are for a S13 then?
How can you tell the difference?
they will fit an s13 or s14, look under my ride section ben i have the same style!
Yeah, but your rides page takes an hour to load cause you have all 2,000 pictures on one page!!
yes they are for both as mentioned by robberto…i would think the full circle would be stronger than the half circle… but who knows… :roll:
ben u can use those on ur car! there is minor differences with the s14 supension! and that piece is the same!
Yep, even r32 uses the same RUCA as s13, s14, z32, and cefiro…
OK, thanks guys!
Darn that RS13 for leading me astray!! Just kidding around, thanks for trying to help!
So are you supposed to put the single arm on the front side of the shock, or the rear side of it?? or does it matter?
dont make us ladys fight u ben
No one on here knows where I live!
