I put my Aeromotive AFPR on my 1G tonight, and I’m having problems with it. I’m out of ideas. Boost leak tested it before I installed it, stock FPR works perfect.
First start up, bogged down and stalled. I upped the pressure to 45 or so, and it ran fine. Lowered the pressure down to 37-38, and the idle was fucked up. I adjusted the BISS, and got it to idle better (it’ll run now) but it stutters under driving.
It has an Autometer Sport Comp gauge on the regulator.
My vaccum dropped from 18-19 at idle to 15-16.
This is my first time using a AFPR, as I only had a 190 on my 2G. Car is mostly stock, minus an 3" exhaust, Supra TT pump, K&N, MBC.
Any ideas here? I’d like to get this thing running right by tonight.
how does the regulator raise fuel pressure, if it does? is it a 1-1 setup? so base fuel press is at say 40 psi. every lb of boost it would see, it would raise fp equallly. example, stock 40. at 10lbs of boost, fp should be 50. Im not sure if dsms use a rising rate fpr. need to know that. Myabe u got the wrong regulator.
so they are saying the stock fuel pressure at idle should be 27lbs… but if you take off the regulator port, and block it off, you set fuel to the 36-38 range and leave it at that… thats if im reading the graph correctly… But dont make sense, b/c if he was at 45 base, and then added boost to it, you would think it would have fouled the motor out bc that is almost double than what this chart says
the problem he’s having is that the gauge on the regulator is saying 38 but the car is stalling, rough idle, backfiring while driving because the fuel pressure is too low. it’s either the gauge is off or the regulator is fucked up because he shoulndt see that on stock 450s until down to the 20psi range base pressure. but what the hell do i know
slap the stock fpr back on, and test fp w/ the stock fpr. test drive it, if it runs good, then park, slap aftermarket one back in, and set to same specs as oem fpr. If it shits the bed, then call and bitch to the company u got it from. just make sure u use the same fp gauge for both readings.
read my first post i said the gauge is probably the problem but the way you wrote it it sounded like you wanted him to use a different kind of gauge like in dash or something
