alot of this stuff still on the car you can check it out in working condition, depending on how many people want stuff i’ll start pulling it off
s14 sr engine harness ready to go for usdm s14 chassis - 300$
s14 sr stock ecu - 150$
apexi s14 hybrid fmic kit, w/ adopted stock rebar ready to go with it, direct bolt on to stock s14 sr, looks bone stock under the hood, no need to cut anything or relocate battery, has a dent in it no big deal - 350$
s14 sr complete head - 250$
sr cas - 150$
s14 sr shortblock, burns oil needs rebuild, complete with lower pans and full timing assembly - 200$
apexi sr downpipe w/ aem wideband bung in PROPER location - 90$
magnaflow 3 inch high flow cat, flanged, ready to bolt on, works with both STOCK and 3inch exhausts/downpipes - 160$
apexi afc neo - good condition with harness - 250$ (I can leave this wired to the engine harness)
spare tranny for sr - 120$
s13 vlsd - 120$
s13 nissan stock exhaust amazing mint - 150$
s13 stock tierods - 50$
s13 stock tierod ends - 50$
s13 sr parts: lower oil pan - 60$; timing cover w/ oil pump - 100$; timing chain - 30$; chain guides - 20$; tensioner - 40$; rear main seal - 25$; thermostat housing - 20$; other stuff also avail. pm for specific part needed.
