air bag suspension
what’s a complete set up cost… everything, compressor, bags, brackets, etc… all the kits i found online were missiong one thing or another. :hs:
For what?
www.suicidedoors.com has a lot of complete air management systems, but unless you’re bagging a truck his brackets won’t help you.
96 impala… 06 impala… just wondering (dreamin). it seems safer to buy a full kit from one manufacturer so it all sets up and nothing is missing.
check these guys out too. They are local, and the stuff that I’ve seen them do is pretty impressive.
http://www.shopofdrop.com/
^I have heard of them as well, i heard they do some crazy layouts, ^
Im just guessingif you use Air Ride Tech. you’ll prolly in the area of 3-4k most likly including installation, but all depends on
-size of lines
-# and size of compressor/s
-3 and size of tanks
-type of pressure gauges, like dual needle per gauge or digital, or which set up.
no one makes a full kit for any car. it is sold as front kit, rear kit, and air management kits. but like first-bass said you will be it the 3-4k range for just the kits then you got the cost of having it put on. you would need to have a main stream car to find a bolt on kit anyways.
