ok guys, see if you can help out on this one. i got a gt40e intake. since the lower is the same as a gt40 no biggie right. but i dont have a provison for a air charge temperature sensor. do i need this sensor or not… this sensor is in the number 5 bank
i have it… so does shag
yesnomaybe
found out i need it, to monitor another A/F but that means i need to tap my intake
do you have the harness for it? sensor worthless without it.
of coarse you need it … monitors a/f and also timing pull based off knock.
AGREED
