For some reason my oil pressure was like 60lbs (according to dummy gayge) and I just had the oil changed so I’m like WTF. Basically I’m getting white creamy stuff in my oil, I don’t think its coolant after further inspection, and my temps are fine, so I think I’m getting air in the pan for some reason.
I also have a bad tranny fluid leak. Not sure where its coming from yet, but it appears to be leaving puddles on the passenger side, probably the tranny cooler. Common problem?
its most likely condensation that or the intake gaskets are leaking coolant slightly into the oil. Those engines were common to get condensation from sitting. Look at the bottom of the oil fill cap it should have a whitish goo, oil vapor and water vapor condense together to form that.
on a side note aint it cute how you guys answer each other on line like that… call him up and talk lol
