AMS-Absolute Motor Specialties Inc, is proud to debut the AMS Max-Slot (26) F and R Direct replacement rotors! These will be officially released at the onset of SEMA this November! Full inventories will go on sale shortly thereafter.
Product Description:
AMS R35 GTR MAX-SLOT (26) FLOATING ROTOR
• 2-PC 15” Slotted Direct OEM Replacement Rotors
• Aircraft Billet Aluminum Centre Hub for Un-Sprung Weight Savings and Strength – OEM utilizes iron hub
• T6061 Aluminum Hub not only reduces weight but improves heat dissipation.
• Approximate weight savings of nearly 1 lb per rotor! This is the equivalent of shaving approximately 16 lbs on the chassis with an added benefit of improved steering response and brake feel!
• 26 Diamond slots per rotor! Slots provide for aggressive bite and superior wear properties unlike crack prone x-drilled variants!
• Diamond slots provide for improved venting vs. standard slots!
• Proprietory Cast Formulation ensures OEM or better characteristics!
• Precisely balanced!
• AMS Laser etched logo on aluminum hats
• Hats anodized stealth black for stock appearance and added longevity
• AMS Slotted Disks are also available separately with OEM quality fasteners for mounting on OEM iron Hats!
• 2 PC rotors are priced less than OEM units and the competitors replacement rings alone! No GTR Tax applicable!
• Strict ISO 9001 Manufacturing Standards ensure first line product
• AMS-Absolute Motor Specialties Inc. has been developing parts, service and tuning since 1992 for Nissan’s flagship vehicles!
• CRYOGENIC TREATMENT OF AMS MAX-SLOT 2-PC BRAKES and/or AMS Slotted DISKS also available! –Deep cycle computer controlled cryo freeze treatment removes and eliminates any thermal stresses in the rotor. The components structures are more uniform which dissipate heat quicker and increase durability! Used by all the major levels of motorsports from brakes to engine internals!
AMS R35 2-PC F - $1169 USD*
AMS R35 2-PC R - $1169 USD*
AMS R35 Rings F - $849 USD*
AMS R35 Rings R - $849 USD*
*Prices for a pair! Rings (disks) come with all OEM quality fasteners for fitment onto
OEM iron hats!
