Differnt outcome form the M3 vid, but shows once again that If you lif tmid corner, you’re fucked. I don’t care if your car has 1243–912834012893=1 wheel drive and all kinds of electronic BS, ghizmos. Physics > engineering bitches. No offense Chuck.
Lucky he didnt clip the rear
Im not familiar with the term lift with cars… please explain
^^i had to look it up myself.
What i got out of it, is when you lift off the accelerator going into a turn, you remove any force keeping the rear wheels planted, so when the front dives down into the turn, the rear tires lose traction causing it to come around. I’ll find the link that i grabbed the explanation from in a minute.
not it but found it quicker: Lift-off oversteer - Wikipedia
Lift-off oversteer (also known as snap-oversteer, trailing-throttle oversteer, throttle off oversteer, or lift-throttle oversteer) is a form of oversteer in an automobile that occurs when the vertical load on the tires shifts from the rear to the front quickly due to throttle release while cornering. This decrease in vertical load causes a decrease in the lateral force generated by the rear axle, so the axle starts to accelerate towards the outside of the turn. This steers the car more tightly into the turn, hence causing oversteer. In essence, this means that easing off the gas causes the rear wheels to break away suddenly, with the potential for the car to leave the road tail first.
Ok, i follow… same as with a bike… smooth = fast…
thanks
come in slow before the turn and come out fast.
TD that people had to look that up… LoL
I was always afraid to lift in turns at dunnville from these videos lol
Modulation is key. Some lift can benefit in some cars.
All depends on the car, and the driver.
that was a nice save.
but there are many reasons TO lift in a turn!
as newman said, great save (whether it was skill or luck shrug)
QFT.
Lol.
He WISHES he could do that.
Scary thread.
