hey i have a Pioneer in-dash DVD player model #AVH-P6600DVD, and last night when i went to open the screen once it came out it worked for like 5 secs then the screen went blank. I opened and closed it a couple times and the samething, 1 of the times it stayed on for like 10 secs then went blank. but the whole time the radio worked
green video wire, is it still connected to ground? Im pretty sure if disconnected it’ll say “Video disabled for saftey” but im not certain, other than that the same thing happened to me with my older pioneer and i had to send it out for repair, twice, they never did tell me what happened to it, but the repair was flat rate 190 bucks, then it gets a 90 day warrenty.
id have to play with it myself a little but check that green wire out, should be grounded
foz or Todd may have some other input on this as thewy also do/done a ton of car audio, but I know the green wire controls the screen itself, but i also belive it still works for radio stations and all, so yours may be malfunctioning
I don’t remember the exact radio you’re talking about but… if it’s a two piece unit, than The screen is seperate from the rest of the unit, and could be a bad connection. On the other hand if you can hear the radio, but can’t see anything it could be a connect internally between the screen and the radio. If it’s the brake wire it would have word across the screen. I’ve seen a couple screens get a crack in the ribbon cable between the monitor and radio which could cause an intermittent lose of display.
I’d say bring it down to First Bass and let him play with it, maybe take it apart. I’d prepare youself incase it does need to be sent out for repair. Maybe borrow a radio from a friend, or dig out your factory one so he could throw in for you while you wait for your radio to get serviced
