Here is a mostly complete 6-speed setup pulled from a 2000 A6 with a blown motor.
120k miles on everything except the trans. The trans was a used unit swapped in when the original trans had a shift collar failure. It has no leakage and all gears engage smoothly on the bench.
Included:
01e transmission w/ mounts, linkage and speed/reverse sensors
2.7t spacer plate, reverse and speed sensors w/ harness pigtails
120k clutch slave (should probably replace)
4 axles. The two front axles need new outer boots.
Drive shaft
Rear diff, no signs of leakage
Flywheel, clutch & pressure plate. Clutch was replaced when the trans was swapped so it is very new.
Nuespeed short throw shifter w/ TT knob. Shifter box, forks, etc.
You will need a pedal assembly, clutch line and a few small things to complete the swap.
$1700 obo
Everything will need to be picked up in Rochester, NY.
Please PM me with any questions. Thanks for looking!
