I have a 01e 6 speed manual transmission. Mileage unknown but it shifts smoothly and all gears engage easily on the bench. Fluid was clean and I removed the debris magnets and found no signs of damage or unusual wear.
This transmission came in the B5 S4 & C5 A6. If you have a 6-speed S4 chances are you will lock up your 1st/2nd collar at some point.
I also have the clutch & flywheel, shifters, linkage, axles, drive shaft, etc.
$1100 OBO picked up in Rochester.
