Ok, for the life of me I can’t seem to figure this out…
I have a Kenwood 428 deck hooked to an Alpine F407 amp. The amp is directly connected to the battery + and - which is right beside it in the trunk. The ground cable is shorter than the + and less than 18".
When my car is off, the system sounds fine… maybe a tiny bit of hiss/distortion which could be normal, but when the car is on, i get a high pitch whine which varies with the speed of the engine. The volume of it does not change however. So cranking the stereo usually masks it.
So from what I read it appears to be a ground loop… And I don’t know what else to do!
So far I’ve:
Replaced the Deck.
Replaced the Amp.
Run an ipod through the rca wires the stereo uses to check for bad wires.
Tried multiple grounding locations, (Stereo harness, antenna, battery, hole drilled in frame under the stereo.)
If I plug an ipod or device straight to the amp, it gets rid of the whine and distortion. So I thought it was the deck since it was an open model… but replacing it didn’t help.
The RCA’s are going to the amp, and i’ve hooked all the speaker wires on the harness up even though they’re not really doin anything…
Now originally the unit wouldn’t power on when i connected the ground via the factory harness. Only when a hole was drilled in the frame, or antenna plugged in would it come on. Could my car have some major grounding issues? (Passenger window doesn’t work, heat gauge bounces, car stalls after putting clutch in at high revs, alarm acts funky etc)
What I dont get, is if it was coming from the deck or wiring at the deck, would the whine not be amplified by the amp?
VERY CONFUSED!
James
