im picking up a crx sometime this week and it comes with a b16a swap which i have no need for…
here are the stats of what comes with it:
Full b16a swap from an integra Xsi from hmotorsonline. (just no axles)
y1 tranny w/ LSD
3rd gear high rpm grind (FREE full brass sychro kit from gearspeed for y1 to fix it, $225 value)
HASport EF (88-91) Mount kit
HASport EF (88-91) Shift Linkage
2 pr3 OBD-0 ECU’s
N1 pulley A/C and P/S deleted
8lbs flywheel and fresh clutch oem replacement about 5k on it
looking for $1500 for everything
normally the swap from hmo is $1750 + shipping + hasport mounts/linkage…
http://hmotorsonline.com/shop/sc2000search.cgi?what=page&item=30001
              I almost bought this swap from the guy your getting it from. He’s a good guy, swap is in great condition and that blue cover is ballin.
              would u sell JUST the motor and flywheel?
buddy of mine needs a motor for his Integra
              sure. $700 sound fair? also the timing belt and waterpump were replaced 10k miles ago.
              my buddy and i are tryin to figure out eerything else he would need. then hes gonna get the money together.
              he would need just axles unless this is going into a crx hf or civic std…
                dc2nick
                    August 27, 2008, 12:01pm
              10
              we would just be taking the Motor and flywheel. Its goin in an Integra LS, and we would just use the LS tranny and axles.
oh ok, that’s easy enough…
              how many miles are on the motor btw…
              10-12k miles after the initial purchase of the swap from steve at HMO. original owner also put on a timing belt and waterpump at the time of the swap.
              might want to mention that the swap was pulled due to the car being rear ended and not due to some mechanical failure. also explains why it was used so little after being swapped. ;D
              idk like $400 since it’s the LSD version.
