Brake Lights...Ain't Working!
hey guys, my brake lights aren’t working…yes I checked and replaced my bulbs even though the wires in them weren’t broke or anything and yet they still don’t work when i push down on the pedal.
Any ideas what to look into next? It’s odd cuz my night time running lights in the rear work when i put them on but there’s like no feed from the brake pedal to the brake lights.
any help is appreciated, thanks.
fuse?
Brake pedal switch? Grab the FSM, do a resistance test of the component isolated from the car, and compare it to the OEM FSM suggested number. Also you could diagnose VIA the flow chart in the FsM.
Did you check the obvious? Fuses, switches, wires, etc…?
FIXED.
LOCK ER’ UP!
