built rb26dett motorset fs
** Please fill in all the fields before creating the thread **I would lke to sell this as a complete set.
R32 rb26dett block and head
block has been balanced and blueprinted,
bored .020 over ,
nismo bearings
cp pistons
cryo-d connecting rods
crank has been pulled and re machined for the N1 oil pump
cometic1.2m head gasket
head
5 angle valve job
stage 3 port and polish
planed head
stock cams
overal
750cc msd injectors
hks fuel rail
aeromotive fuel pressure regulator
apexi power fc d-jetro w/ 2 map sensors
apexi power fc commander
turbo is polished holset hx 35, with high interference exhaust wheel
4" turbo inlet 3" v-band clamp exhaust outlet
tial 4mm waste gate with .9bar spring and screemer pipe
ex engineering exhaust manifold
this motor was built by taylor and sons
this motor made 440rwhp at 12psi and 345ftlbs of torque
this motor was built for 600plus hp, but not run higher than 15psi,
this is complete and ready to run , i also have an rb25 tranny for this motor and the wiring if it was to go into and s13 240sx
looking to get $6500. for this setup
thanks
Bryan
That wastegate is weaksauce! J/K Bryan is that the 40 or 44mm?
And is that RB25 tranny included … that was unclear.
Sick deal. I’ll spread the word.
44mm.
bryan
Retarded deal…this is almost crazier than my pricing.
bryan, if you do decide to part, i might be interested i one or two things
sick deal tho
try gtrc if you havent already
this motor can be seen running , if the weather is noice i might be able to drive the car
farmer
