-red top sr20 compression 155-160 all cylinders . In car running
-tomei pon cams
-bc titanium retainers and springs
-new valve seals
- 3 angle valve grind , mild port . Head decked and cleaned
- greddy rocker arm stoppers
- arp head studs
- apexi head gasket
- new water pump and t stat
- new updated chain and chain guides
- new front and rear main seals
- Garrett s14 t28 bb turbo
- braided lines with s14 water neck
- Megan stainless manifold and turbo elbow
- thermal intake gasket , 7 layer exhaust gasket
-5 speed sr20 trans with short shifter
- your pick abs or non abs shaft
- light weight flywheel
-exedy stage 2
can include other excellent s13 and swap parts will make package deal .
