hey guys i had originally planned to put this in my e30 but i decided to use the sr20 i used for mock up and sell this so i can buy another project car i had in mind…
here are the parts…
blacktop sr20det originally
completely rebuilt with zero miles
(named from top to bottom)
valve cover wrinkle painted
all new oem gaskets
valve guides
supertech valve seals
oem valve springs and retainers
circuitsport rocker arm stoppers
timing chain kit
head machined and resurfaced
high temp ceramic painted head
cosworth 1.1mm headgasket
arp headstuds
factory cams
block machined and coated with high temp ceramic paint
oem crankshaft
oem pistons
oem rods
nissan main and rod bearings
oem thrust washers
s14 oil pump rebuilt with new pump gear and seal
oem crank pulley
light weight alt, ps, wp, pullies
water pump
oem oil pan
circuitsports thermal intake manifold gasket
cleaned factory intake manifold with ceramic high temp paint
high temp ceramic painted oem exhaust manifold
oem throttle body
s15 480cc injectors
factory fuel rail
hks ball bearing gtss turbo
good year stainless steel lines water and oil lines with thermal sleeves
3 inch stainless o2 housing
os giken twin plate clutch
sr20det transmission
drive shaft
no name short shifter
hks ssq bov
rb26 maf
s13 tuned computer for this set up
igniter chip
coil packs
cas
all sensors needed for motor
plug and play sr wiring harness ready for s13
every single bracket cleaned and painted
everything has been documented for this motor and i have lots of pics of the build through out
most of the parts came from frsports.com and a few from members on son240
and machining was done at speedy machine shop in newmarket
i put a lot of time in this motor and didnt rush any of it. im sure there is someone that can appreciate this thing as much as i do
compression test will be done in front of buyers
looking to get $3700obo
can be delivered to gta… if further…
you can pay for my gas
or come get it yourself in Aurora Ontario
i will also put this on ebay tonight
text, call or pm me at 289threethree84044
please text me if i don’t answer i might be working
thanks in advance for looking
here are some pics of the motor as it sits right now
