c5 corvette steering wheel hub and QR??
so ive been looking for years and still havnt really found a after market steering wheel hub and quick release fitment specific to the c5 corvette. i have talked to some and some say its bc they dont make one and a wheel will bolt right up to the stock assy.
friend of mine had one on his C5 and it was an NRG hub i believe.
http://www.swapshopracing.com/contents/en-us/d746_NRG_Quick_Release.html
im going to call them today and see what the deal is but i thought id ask here and see if anyone knew or could help me out.
http://ltbautosports.com/chco69.html
http://ltbautosports.com/ltbquicrelsp.html
Get a NASCAR set up
this is a joke right?
fyi, the splined ones or the hex nascar ones get sloppy over time. The captured ball ones like NRG are better plus you can only put them on one way.
how hard is this to install?
after you pull the stock wheel off and assuming you don’t want to weld anything, you need an adapter that has the correct spline for the stock column and then it is 6 screws to attach the QR to the hub adapter and then 6 more to attach the steering wheel to the QR
yes i found that, its in the links i posted above. how hard is it to pull the stock wheel?
Not hard at all Eman.
stop getting so big.
not sure if i get what your asking, but hub has to be for your car, which it seems you have found, quick release is not a car specific part but make sure that the quick release/hub/steering wheels all have the same bolt set up, like for example momo bolt pattern. most of the quick releases/hubs now days have multi-patterns though so they will fit everything.
i found everything today like it has alwaus existed but have looked numerous times in the past and havnt found shit. lol
but yyes everything i found matches up. thanks
I thought we discussed this: http://prattmiller.com/
Go full retard or sit down.
C6RS steering wheel; $1,295. Lets make this happen: http://prattmillerc6rs.com/pricing.htm
taking donations now
I heard a kidney goes for a few grand these days.
5 min. pull the wheel off, put the new hub on. wire the horn. it’s only 1 nut
ok how the fuck do u get the airbag off?
I got this eman lol
cool, ill bring u a bigmac
there are typically “trim plates” on the side of your steering wheel. you pop those off and then unbolt the airbag and disconnect the electrical connection
