camaro/firebird, adjustable lower control arms and panhard rod ( LCA PHR
Made form solid alum, very strong and super lightweight. Rod ends are 3/4 QA1 XM one end right thread other left. Chromoly self lubricating & self sealing, Teflon and Kevlar Race. They are clean and tight with no free movement. Bushing are press in, and a tight slip fit over the metric stock bolts, easy to work on and with not having them lose. And stepped to fit tight and not make noise like the loose spacer 3 piece bushings do. PHR bushings even have the stepped hole to fit tight on the stock bolts stepped thicker bolt shank. LCA bushing are offset for allow for more tire room, or adjustable shock knobs or drag swaybars.
$150 LCA
$80 PHR
$200 for the pair as the lowest price
ye ha
jeez this is exactly what i want, should interchange with 3rd gens correct?
yup 1982-2002 GM F-Body: Camaro & Firebird
Nice product! send me a set!!:d
SOLD
