selling my motor from my 89 lx …
stock shortblock 80k
GT40 irons from a 96 explorer (cut down to 58cc)
TFS1 cam
explorer upper and lower
trick flow 70mm t body
FMS 24lb injectors
edelbrock water pump
pro m 75mm maf for 24lb
holley adjustable FPR
FMS wires
MSD cap and rotor
all parts except intake and shortblock only have about 10 miles on them … i just wanted to get the car running then i took it off the road
motor runs amazing … oil pressure holds great 75psi cold … after 1/2 hour runtime and a couple mile drive she sits at 45 psi hot idle
i will also throw in a msd 6a … and comp and harness also
will let anyone hear it run before i pull it … i would just need a set of stock or shorties
looking to get $1000 for everything
call or text anytime if you wanna check it out
thanks Derrick 716-310-9347
