Originally posted by Gnocide well id say one at a time with no throttle, but im no mechanic. well shade tree maybe
& disable the spark & fuel!!!let the motor spin at lease 3 times!!!
i pull all 4, and go wide open throttle w/ coil and lead to injectors un plugged so no fuel or spark is given.
if u go one plug at a time, and air is leaking to the next cylinder, it will pressurize still b/c that chamber is sealed. however, if that cylinder has the plug out, then the air would blow out if you were in fact leaking.
kinda like doing a leakdown test. pull all the plugs out, and set piston manually to a bit b4 tdc, and run the test. u’ll hear where air is leaking, as well as the reading on the guage telling you the % of leakdown.
