How do i get that error loading thing to go away, about 1 of them pops up every 10 seconds and i dont know how to stop it :eek4:
download and run this, kinda looks like you have spyware
http://www.microsoft.com/athome/security/spyware/software/default.mspx
…because you are chatting with so many hot babes online
list your running services…
I just downloaded that program, and it found 7 instances of spyware so far… :mad: Ad-aware and Spybot missed them all.
make that 12 instances of spyware not found by any other program… :rant:
We’re sorry, but we were unable to service your request. You may wish to choose from the links below for information about Microsoft products and services.
If you have a pirated copy of windows then you won’t be able to download it… :hs:
sounds like cnbabe = bad porn links
best bet is to kill the service, as i stated, please list the current running services.
You know what’s wierd? I have giant anti spyware on my computer at work, and I can run that and clean up the spyware, and then immediately run ad-aware se after that, and the ad-aware will still find more that giant did not. Wierd. :dunno:
I have downloaded and run 5 different spyware removal programs and every one of them has found different things. they are all different and you would have to have 32.5 different spyware programs to clean everything
I could give a shit about spyware anymore. I just run ad aware every now and then and don’t download shit off of kazaa anymore. if the pc gets too slow, I just ghost it and it’s back to normal in 5 minutes.
i run no ‘spyware’ applications… a lot of the time, the actual scanners will leave files on tnhe pc to dump services after a reboot that will come up as spywar’
so jinxy or whtaever… when you run teh on program, it’s creating an answer file and a delete bat file (essentially) that when you reboot and windows iniitalizes the delete file kills pests before they load, then write to an answer file which allows windows to load services as usual… this is why if you run a scan and then don’t reboot, you may see more files being picked up.
also all scanners are not equal…they all base of similar ideas, but the ‘definition’ files are the strings for seraching… they get updated and some companies have more money into R&D for weeding out pests than others.
best bet is to install windows and understand which services are required… then create a profile with limited rights and do not allow pests to become a problem
or just let them fuck up your computer and then go out and pay someone like me a lot of money to do a little work.
either way works for me.
I have heard a lot of good things about Microsoft’s program. I may try it tonight. I have a piece of spyware I can’t seem to remove with ease. It’s one of those edit registry, rename this file, reboot, go here, do that. ugh!
i’ll remove any spyware for anyone for $50 :finger:
ugh if you were only closer!! ha ha
remote assitance + paypal = teh win
i can remote into your stuff… wouldn’t want to find any male pRon or anything, so that’s why i don’t work on women / b_rad’s computers… ![]()
ps. in seriousness, i will help remove it if you can’t.
I have a TON of naked man pics on there too ![]()
I will let you know. I found a fix, it just involved MANY steps.
Thank you so much for your generosity!
any of you?
feel special… only happens once in a while. :dunno:
