The driver side corner light doesnt work at all. Thought it was the bulb so i switched the bulb and its not the bulb. Doesnt come on when i turn the headlights on and wont go on when i turn the turn signal on. What could be the reason for it not working? PLEASE HELP!!!
Is there corrosion in the socket? What kind of car is it?
wiring. if its an older car corossion, bad grounds, or broken wires.
its a 93 honda civic
Check the socket, check for bad grounds, and check for broken or loose wires.
would i be able to check for continuity if i use a voltmeter?
I had a 92 hatch, I think I had to swap out 3 corner light pigtails on it. That’s likely it. Check for corrosion in the wires or the socket itself.
Yes
