What is it, like 1 foot?
I forget.
I forget.
I have used a 12" crossover without any problems
11.6219475" anything less will melt…
i don’t think their is a minimum. never heard it…
Regular Cat-5:
Gigabit Ethernet (over copper), 1000baseT
Speed: 1000 Mbps
Max Len: 100 Meters
Cable: UTP, RJ-45 connectorsFast Ethernet, 100baseT
Speed: 100 Mbps
Max Len: 100 Meters
Cable: UTP, RJ-45 connectorsTwisted Pair Ethernet, 10baseT
Speed: 10 Mbps
Max Len: 100 Meters
Cable: UTP, RJ-45 connectorsThin Ethernet , 10 base 2
Speed: 10 Mbps
Max Len: 185 Meters
Cable: RG-58 type coax, 50 ohm impedanceThick Ethernet, 10 base 5
Speed: 10 Mbps
Max Len: 500 Meters
There has to be some specifics on the box if you bought some. . . or if you made them on your own >.> dunno
At least this is some reference. . . and 100+m wow… 2 feet? heheh
:o Come on google > Howie
http://www.cat-5-cable-company.com/faq-maximum-length-cat-5-cable.html
EDIT: OH Minimum T.T Tee hee hee
he wants minimum length… of which i dont’ think there is one.
i’ve done punchdowns with less than 6" of cable in a crossover setup…
It’s not the size that counts…but I’ve used 3" cables in racks before…
yea i didnt think there ever was a minimum… doesnt make much sense? the only thing that makes a crossover a crossover is the wiring so i assume u could have it as long at u had enough wire to cross it inside
minimum? don’t think there is one, can’t imagine why.
the one i keep around is about 2 feet, but i’ve used shorter.
edit:
[quote=“Google”"]
I can find no minimum length in the chunk of the specifications I have for 100BASE-TX cable. I read one Internet source that said it was .5 meters (1.6 ft.). I have read others that said there was no limit. I have a 2-foot crossover cable that works fine. There are loopback plugs that have almost no length. I would tend to make such a cable at least two feet long to permit some noise attenuation by the twisted pairs. However, RJ-45 plugs are cheap and one could experiment for a modest cost.
[/quote]
In all the cisco classes I have taken there is no minimum lenght
3 feet is the minimum… anything less and the quality of signal is degraded.
Yup… I’ve never had problems with shorter, but technically 1m is the minimum recommended length.
