Dash light issues
Hey just for reference this is a 93 coupe. Somtimes when I startup my car the dash will not lightup at all, though it is working as tach is moving as well as gas gauge and that that stuff. After driving for a while it will randomly come on. The clock works when I get into the car but as soon as I turn around it turns off with the rest of the dash.
Somtimes I wont have this problem and they will be on from the time I start my car(usually after I turn it off then on again within 5 minutes)
Any idea on to what this is caused by. I was told it could be wiring in the wheel well.
Thanks in advance.
Yeah, you need new wheel wells for sure man.
huh?
lol
noga jack ur car up on the front drivers.
look at the harness in the wheel well.
ur car is lowered and ur shit is fucked. haha
solder it all back and tie rap it up higher in the fender
later
if thats not the problem then good luck!
That’s likely not the problem as I had the same issue even when my 240 was stock. It only happened when it started to get cold out though. Once the car would warm up they’d come on.
Once I got new wheel wells it worked fine.
