difference between sway bars?
i bought a hicas shell, it doesnt have a front sway bar, i have one on my 89 240 im wondering if the hicas had a better sway bar at the front, im aware the rear one is better, is the front one better as well?
The thing that are different, is that the hicas sway bars are bigger.
^^^ huh?
afaik, the front sway bars are identical on all S13s.
They’re not the same, 100% sure. I had an Hicas and Non-Hicas models before. The Hicas sway bars are much much much thicker.
ok thanks…i guess i better get a hicas front sway bar crap
as said above the front are the same, it is only the Rear that are diff becaue of the Hicas subframe
thanks benson i know ur 100% correct
So why does my ES bushing set come with 2 different sizes for front swaybars?
I was pretty sure both front and rear were bigger.
from FA:
S13 sway bars:
'89-'90 base: 24mm front, 15mm rear
'89-'90 sport package: 25mm front, 17mm rear
'91-'93 base: 25mm front, 15mm rear
'91-'93 HICAS, “JDM”: 25mm front, 21mm rear
heh
the 24mm front bar is on convertibles
coupes and hatchbacks (regardless of having hicas) are 25mm front
non-hicas is 15mm in the rear; hicas equipped cars = 21mm rear
I’m pretty sure my coupe has a 24mm swaybar on the front
From what i have hird that the front sway’s on non hicas are like 19 mm
well you heard wrong
I gess so
what kind of motor are you running?
what’s your setup?
John
Why are you arguing about standard anti-roll bars, get Whiteline/Cusco/nextbrand upgrades and be done with it.
