Figured i may as well start a thread mid-process. Since i now have 2 kids, I chose to put each kid in their own room up on the 2nd floor, plus there is a loft up there that can be used as a play room which keeps everything up there.
So I decided to put a bed/bath in the basement for the wifey and I …as well as help make the unit more rentable when it comes time.
here was the clean slate, the day i took ownership:
Here’s a general layout of the basement and what i’m hoping to accomplish:
What needs to be done:
1.) Move support post: one support post is in the proposed living space, and will be relocated. W8x15 support beam can support the added unbraced distance of the support relocation
2.) Add a decent sized bathroom: Install a bathroom in the proximity of the existing sewer line. sewage pump will need to be installed to pump poop to the sewer
3.) Storage Space: Would like some decent usable storage space
4.) Bedroom and Closet: add a decent sized bedroom and closet, keep the high cielings where possible and adding drop cieling where needed to access utilities above.
I decided to go with steel beams for the framing for a few reasons. 1.) the walls are not load bearing. 2.) steel doesn’t warp or mold 3.) Price is nearly the same as a wood 2x4. 4.) lightweight and easy to handle. 5.) I like metal.
