a shop told me my crank angle sensor was broken but ppl on forums say that the ka24e dosent have one or dose it? isnt located on the distributor? why wouldent have one? srry for being a nooob but im only 16
its in the distributer, under a protectective plate under the rotor,
you probably find a good used whole distributer from someone on son
ok because ppl have been telling me that the ka24e dosnt have one but i want to make sure do i take the distributor out and spin it by hand and at the same time having the volt meeter on the crank angle sensor and the ground?
some people probably think of it as a cam angle sensor which is why they say it doesn’t have a crank angle sensor. these people are stupid because it’s fed off the crank. twin cams don’t have a crank angle sensor because their’s is fed off the cam (it’s inside the distributor, too).
ok on a forum i read thers no way of testing them, you have to take it apart but im pretty sure there is a way of testing them without taking them apart
