hi i tested my crank angle sensor but i dint know if i did it right. i pulled out the distributor and turned it by hand at the same time holding the volt meeter to it and the ground? did it do it right?
You can just measure resistance across the terminals, you will be measuring dc resistance of the pickup coil. For actual resistance value have a look in your service manual.
