So as most of you know I picked up this beautiful $500 Eagle Talon TSI.
Thing runs awesome… when it starts.(Bought the car knowing this)
Car info:
1995
Eagle
Talon
TSI AWD
Automatic
No mods.
Background:
I bought the car knowing it had this problem. Sometimes, the car does not even make a noise sometimes when you turn the key to start. The original owner put jumper cables up to it, messed with the terminals and the car started right up nothing funny. I figured it must have been the battery/Terminals. I cranked the shit out of the terminals on a new battery, and the problem persisted. So I took the starter motor out, had that tested and it passed with flying colors. I then put everything back together taking great care to clean the connections and make sure everything was where it needed to be.
Oddly enough, sometimes the motor just would crank over like a few times very very slowly. But the weird part is, sometimes I never get even a click, the lights on the dash don’t dim or anything.
So I hook up jumper cables assuming maybe my new battery is flattening out, and what do you know, after fucking with the terminals and what not, the car starts right up.
I take it for a ride, park it. Turn it off and then try to restart it. The car hesitates to turn the starter over but then it went full speed and started the car. I tried this about 3 times in a row and it worked every time.
I waited about 3 hours and go back out to the car, sit in it turn the car to the “on” position, all the lights on the dash are strong. I go to turn the car over and… Nothing. Not even a click!
I don’t know what gives, but It’s gotta be either the starter isn’t getting the signal it needs to draw enough power. Or that there is somehow a shitty connection between the starter motor and the battery(Hence explaining why jumping it will cause the car to work)I will admit the grounds between the battery, firewall, and starter look kind of rough.
Gimmie some ideas because now I don’t know where to start.
-Sobo
Gah every new car is a new adventure with a new problem. FML!
Thanks!
