E85 Evo fuel mileage..
26
Yes, and make sure the lines are compatible.
Lines should be fine.
He’s going to need a goddamn garden hose for fuel lines
I know, but I’m saying the composition of the lines should be fine. He should run -10AN fo’ sho’.
Nope. -8 (1/2") is MORE than enough for ANY car on this site on E85. -6 (3/8") is good for AT LEAST 800WHP on E85.
Oh, and for those who care, the ethanol percentage of the E85 from the exit 23 Mobil tested at 69 percent. Right where winter blend should be.
^What percentage is the summer blend and is there a better station to get it at than others? Thinking about making the switch in my Evo.
I haven’t tested our summer blend yet but it should be right around 80 percent. No idea on the stations as I only use the one closest to me, which is 45 minutes away. AFAIK, all the Mobils are supplied by the same trucks or whatever.
Oh, and before it gets brought up, the anti-knock qualities of E70 are the same as E85. However, E70 will run richer than E85 (which is most likely E80ish, will know soon enough)
It’s not going to stop flowing because it’s fluid, but the pressure drop starts to get pretty high. If you’re running triple walbro pumps on -6 YOU’RE DOING IT WRONG! :lol
-8 all day on trip walbz brah!
