Anyhow, AFAIK you would have to modify the outlet itself to disconnect the top from the bottom. :nono: That’s bad. Code violation I’m sure, probably not the safest thing, etc.
IIRC 87conquesttsi is an electrician so he’s probably already taken care of you, but you have a couple of options:
Leave it as is. It’s not worth the effort.
Rip the outlet apart and cut the drywall to install a 2 gang box and 2 outlets, only one of which has the switch interrupting its power.
2b. When you do all that only to find out that power comes in at the switch, you will have to pull new romex past the switch to the second outlet wishing the whole time that you had just gone with option 1.
2c. If power comes in at the switch, you could just replace that switch with a wirenut sending continuous power to the outlets, and put a switch on one outlet or the device itself locally.
Really? Then why do most outlets come with a means to do this very thing?
A metal joining tab between silver screws 3 & 5. This electrically conductively connects the second halves of the outlet together so that one wire connected to one of the silver screws will serve both halves of the outlet.
A metal joining tab between silver screws 10 & 12, This electrically conductively connects the 2 half’s of the outlet together, so that one wire connected to one of the brass screws will serve both half’s of the outlet.
The metal tab (4 & 11) between 3 & 5, and 10 & 12, can be broken off which will as a result break the electrical conduction between the 2 half’s of the outlet, this may be done for special purposes for such arrangements as…
an outlet that is half switched
a split circuit outlet as use along the kitchen counter.
When you’re bored today spend some time over at that site I posted. You’ll learn a ton about home electrical. Helped me a ton when I was trying to wire the ceiling fan in our bedroom to have full power all the time for the fan but have the dimmer still control the light.
I even went as far as buying the greenly flexible drill bit to go through the floor
while in the wall. I then returned it after 1. drilling through to the outside and 2. breaking it on my second attempt.
This can be done. I’m not going to answer because I don’t want you to burn down your house. If you aren’t sure, you really should call an electrician. That said, there is plenty of info (already in this thread), on the internet in general, and in the front of every Home Deopt store in the book section. I’ve seen some nasty hack wiring in my time, its a great way to burn everything you own, be careful.
