well I dont think they will be geting anymore buisness if anyone reads that. I also remember seen your car at red deer when geting that tranie from you and they put your air filter damn near on the road instead of where its posta be. Good to hear your geting nice power from it now. I will have to get a rip next time I see you and you will prob have your 300hp by then if you keep spending a few bucks on beer and ciggiez.
ANytime i can help you i will
PS thanx for the ride home. FUCK i am drunk’
i thought u were gonna sleep seing u work in 3 hours and 38 mins
ps met the nices cop tonigth showing rob my new found power
Never thought about this myself, when I do the swap down the road, I can do all the mechanical business, but can’t the harnesses just swap over, or do you have to splice the two together?
when i saw the 2 harnesses i just said fekk it and sent it to get done, i’m sure i could’ve done it (time permitting), but it looked like a big headache and i was busy with a timing chain kit, if you have the time, try it I guess, but yeh, you need to splice some connectors to e/o.
The wiring is STUPIDLY easy. It probably took me only 15 min’s to wire everything.
It is probably a total of 15 wires you need to cut.
I feel sorry for anyone that paid for it.
Every wire you need is on here. www.heavythrottle.com
Ahh early morning drunken thread always make my day. :rolleyes:
wow …has anyone had good experience with them? i heard samaru is good with the 300zx…i am planning to put a vg30dett into my 300z but donno now…i herad reg is good and very knowledgable at this. has anyone or known someone who has swapped a vg30dett into there z32? and how was it…and howmuch did it run…roughly…and id ont want to travell to calgary to get the swap done…
sumarus messed my car up really good too back in july. massive oil leaks out of every seal and gasket, took an extremly long time with the swap as well as trying to fix the leaks, the water pump went on me too, they changed it, allthough they POUNED the water pump hub on from a different pump so it seized while driving, fucked my car up some more. as well some ass hit it so the fender is all scrathed up now :finga: i would not recommend them for doing any kind of work, things just go very wrong when you bring your car there and they give it back…
Get Andy at Autodream to put it in for ya
One more story to the list.
how much tehy charge to swap and motor/trans …my z might be sold this week so i m planning to pick up a 240
Don’t do a motor swap…Buy my car with the motor already swapped
but if you are going to do a motor swap my car as “sub-par” as some might call it is an example of Autodreams work. it might not be a show car engine bay but everything works exactly the way it should no problems whatsoever.
+1 for autodream
Anybody know what it would would cost to have an rb26 put in a 180?
Pick up the phone and talk to Autodream. As far as I know, they are the only shop in Calgary that do these, maybe extending to Alberta
