Im buyin a engine temp guage but should I get oil temp or water temp? Or should I get Volt Meter? Just tryin to fill a spot in the guage pod
Water temp is standard, oil temp if you’re racing for hours at a time.
thnx! or should I get Air/Fuel Ratio?
The normal air/fuel ratio gauge tht hooks to your stock O2 sensor is pretty well useless.
Alright im just gonna go with the water temp should I get the one that goes up to 280 degrees or 240 degrees i have a honda with B16
If it ever goes above 210 or so you’re in trouble!
yea i hope that doesnt ever happen lol
