Everything is located in kelowna B.C, accept paypal and parts will be shipped collect via greyhound… or if you know someone driving through pick up is cool too…
sr harness already wired for 240sx $175
sr head needs cam journal fixed $50 o.b.o will get pics…
sr block good condition std. bore $150
sr crank good condition $150
sr stock intake plenum $100
sr chain case cover w/ oil pump $65
sr alternator $75
sr ecu $125
sr ignitor $75
sr valve cover $100
sr coil packs $40each or $120 for the set of 4
sr coil pack harness $25
sr starter $100
sr transmission $200
sr stock pistons/ rings/ rods good condition $100
sr upper aluminum oil pan $100
sr jdm cluster $100
stock t25 with mani/ heat sheild and oil lines $200
sr stock injectors with fuel rail and pressure regulator $100
megan coilovers streets good condition $650 o.b.o
non hicas sub complete with all arms ect… $200 o.b.o
open diff $75
axles $100 pair
walbro 255 fuel pump $75
s13 gas tank mint $50
mint rustless non spoiler hatch 1 red 1 light blue $150each…
more parts will be added…if you need something not listed pm or call me… thanks…Josh.B
1-778-436-9242
