PM or text if interested 705 441 2693
Located in stayner Ontario!!! Can ship cheap anywhere though
SR20 coil packs, $25 each,
SR20 throttle body (will need TPS replaced) $40
SR20 Waterneck $25
SR20 temp sensor $25
SR20 thermostat $25
SR20 Eagle Rods and CP Pistons,
Rods: http://www.frsport.com/Eagle-CRS5365N3D-SR20-SR20DET-Chromoly-Forged-Connecting-Rods_p_1367.html
Pistons: http://www.frsport.com/CP-Pistons-SC7325-325-Nissan-SR20DET-86-5mm-9-1_p_8504.html
Ignore the fact that theyre dirty, pic was taken right when they where pulled.
New these are $1106.32 from FRsport without bearings, plus bearings, plus tax, plus shipping
I’ll sell them for $800 with rod bearings.
SR20 Oil pan, scratches but no dents $50
SR timing chain guides. Like new very little wear $60
SR valve cover, with gasket. $70
SR valve shims, $50
SR20 red top head (with cam caps and rockers, not pictured), about 15,000 miles on rebuild. take all of it $300
lifters $80
rockers $80
springs $40
valves $60
bare head and caps $75 but not for sale unless a few other small things sell off it.
SR20 Oil block with sensor $50
SR20 Cam angle sensor sold
SR20 motor mount brackets sold
SR20 Alternator bracket $40
SR20 Dipstick $40
SR20 Coil pack sub harness, sold
SR20 Knock Sensor and harness sold
SR20 OEM Intake support $20
SR20 Coolant block with sensors and lines sold
SR20 Dust sheild tranny plate $50
SR20 Intake top Half $40
SR20 Intake Bottom Half $35
SR20 Fuel Rail $30, +$10 for caps and screws (not pictured)
HKS Cam Gears, asking for $320, these retail for $380
SR20 Rockers, $80
SR20 Crank Pulley $50
SR20 Head Bolts and Washers $50
SR20 OEM Water Pump with low miles $40
SR Timing Chain, low km $40
DEI Turbo heat sheild and header wrap. its all in there and brand new. $50
Rs enthalpy ecu, tuned for what it says on the cover, 550cc, n62 maf 15lbs $400
550cc 5-0 injectors, $250
Brand new ISIS style n62 maf $75
8mm spacers $20
Rocker stoppers $75
10mm spacers $25
5mm spacers $20
Faze boost gauge (reads PSI) $40
Oem plastic s13 sideskirts $120
Rocket bunny style coupe wing $140
Dodge challenger fiberglass hood skin, can be trimmed for a 240, super light $150
Aluminum wheel with quick release. $150. (comes with other end of quick release)
Pair of 15x8-15 5x114.3 chrome diamonds $180
Full set (4) 15x10-40 chrome wheels. $500
Coil covers $10 for grey one, $15 for oem brown one
S13 Megan rear strut bar $40
S13 No name rear strut bar $30
S13 Jdm front strut bar $50
Unkown random strut bar $10
SR oem heat shield $30
Mint s13 hood $90
Stereos,
Top $20
Middle $30
Bottom $60
Stock sidemounts (x2) $20 each
50mm hatch over fenders. $250
