FMIC-can i keep the stock battery position
Like it says, can i keep the stock battery position or do i have to relocate it?
What kind of motor, FMIC kit???
It all depends if your piping goes thru the battery tray. If it does you need to reloacte or use a small utility battery like me.
samll battery is a mist for any fmic unless ur end tanks are made different! like mine for instance! but if they both come out at the same place then u need to get a small battery, to make things easier put ur battery in when u are making the piping! then u can work around the battery instead of haveing to work arund the allready welded up piping!
My FMIC still has a BIG battery in the stock location with the piping. Not thrulled on the design but it works.
Its CA and the way things are going its a SSAutochrome… :roll:
awww noooo, i got a full ca18 hks kit man, for sale and u can keep stock abttery location!
