Hey guys, I just went out to my garage and cleaned everything out and took an inventory of all of my excess parts and here they are. All Parts are off a 1993 S13.
Make offers on the parts in PM or email me at droppinthesasquatch@hotmail.com , preferable PM
<i><b>1 - KA24DE 1993 240sx #28 ECU</b></i> - Perefect Condition works like butter kept indoors in my closet for protection.
Pic:
<i><b>1 - KA24DE 240sx Coil Pack </b></i> - Very Good Condition Works Perfectly, not needed due to SR Swap.
Pic:
<i><b>1 - KA24DE 240sx Clutch Slave Cylinder</b></i> - Excellent condition, no leaks works perfectly, was removed from the KA incase the stock SR slave cylinder did not work, however it works perfectly and is not needed anymore.
Pic:
<i><b>1 - KA24DE 240sx Motor Mount Left Side</b></i> - Was removed from the KA upon removal from engine bay, no cracks, solid mount with no issues perfect to replace an old broken mount or to fill with polyurethane for super stiff mounts.
Pic:
<i><b>2- KA24DE and SR20DET 240/180sx Stock Shifter w/ Bushing</b></i> - Was removed from the KA and SR upon removal of motor, perfect condition with a fairly new OEM bushings.
Pic:
<i><b>1 - 240sx Stock Shift Knob</b></i> - Replaced with a Razo knob, in good condition for a stock shift knob.
Pic:
<i><b>1 - KA24DE 240sx Stock Down pipe w/ Heatsheild and EGR Pipe</b></i> - Not needed due to SR Swap, in excellent condition for what it is, come with the EGR pipe a non corroded Heat Shield.
Pic:
<i><b>1 - KA24DE 240sx Rad Shroud</b></i> - Taken off the car due to SR Swap, no cracks in excellent condition.
Pic:
<i><b>1 - KA24DE 240sx Intake Piping and Resonator</b></i>- Taken off due to SR Swap, in perfect condition no cracks or leaks.
Pic:
1 - KA24DE 240sx A/C Conpressor w/ Bracket and Pulley - Taken off the KA to try and mount to the SR but it didnt line up at all like Heavy Throttle Said so the lines were unbolted and the system drained. Perefect working order blew super cool air when hooked up.
Pic:
Pic:
1 - <i><b>240sx Negative Battery Terminal Cable</b></i> - connects the intake manifold to the battery tray then to the - terminal on the battery, in excellent shape.
Pic:
2 - <i><b>Stock GE Halogen Seal Beam Headlights</b></i> - Both work perefectly and are almost brand new.
Pic:
1 - <i><b>1990 KA24D Air Filter Box Cover with MAF Adaptor</b></i> - Perfect condition with all wiring and no striped bolt holes, perfect for a sleeper setup.
Pic:
1 - <i><b> Sold!! Stock 240sx Fuel Pump</b></i> - Pump works like butterscotch and ran my SR at 8 Psi with no problems at all!
Pic:
1 - <i><b>1993 240sx Cruise Control Cable and Actuator</b></i> - Taken out of my car because cruise is not usable with the SR, worked perfectly before the swap i used to on my trip to niagara.
Pic:
Pic:
1 - <i>[b]240sx Charchoal Canister[/b</i>] - Taken off my car since I have the SR, no use for it works fine and everything is in order with it.
Pic:
I will Meet with anyone who is intrested at a good time for the buyer and meet at a close spot to the buyer for dropoff.
Stay Tuned for More Parts 8)
