Never used summit 15 gallon fuel cell. It is powder coated black. It has a 90ohm Fuel sender. Its a bit dirty and will need a new rubber grommet for the fuel cap as the orginal one dry rotted from sitting in my 240 in the barn.
$80
New from summit $289
Info from Summit
Brand: Summit Racing
Part Number: SUM-291215-SD
Capacity: 15 gallons
Fuel Cell Color: Black powdercoated
Fuel Cell Material: Aluminum
Sending Unit Included
Sender Ohm Range: 0 ohms empty, 90 ohms full
Length (in) 20.000 in.
Width (in) 18.000 in.
Height (in) 10.000 in.
Outlet Fitting Quantity Two
Outlet Fitting Size -8 AN
Vent Fitting Size -8 AN
Return Fitting Size -8 AN
Sump Yes
Sump Depth (in) 2 in.
Notes: Fuel cell is manufactured from 0.100 in. thick aluminum.
