FS: 16gal Foam Filled FUEL CELL w/ extras
Fuel Cell is new and NEVER USED. Cell comes with foam (to prevent fuel ‘slosh’)
Also has Stainless Braided lines 2 8ft lines with -8 A/N fittings and elbows pictured. Also the vent tube with -4A/N fittings and aprox 1.5ft line. Stainless braided line is from AeroQuip and fittings are “EARLS”. I spent over $150 on the lines and fittings.
SUMMIT RACING DESCRIPTION
        ![http://store.summitracing.com/global/images/1105/r_dt_left.gif](http://store.summitracing.com/global/images/1105/r_dt_left.gif)  ![http://store.summitracing.com/global/images/1105/r_dt_overview.gif](http://store.summitracing.com/global/images/1105/r_dt_overview.gif) [Application](http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D290108&view=32&N=115+4294925239+4294839036+4294920243) [Suggested Parts](http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D290108&view=64&N=115+4294925239+4294839036+4294920243)   [Show All](http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D290108&view=4095&N=115+4294925239+4294839036+4294920243) ![http://store.summitracing.com/global/images/1105/r_dt_right.gif](http://store.summitracing.com/global/images/1105/r_dt_right.gif)      Brand:[Summit](http://store.summitracing.com/egnsearch.asp?N=400304+115) Product Line:[Summit Pro Street Fuel Cells](http://store.summitracing.com/egnsearch.asp?N=400304+305650+115&autoview=sku)  Capacity: 16 gallons   Fuel Cell Color: Black   Fuel Cell Material: Plastic   Foam: Yes   Sending Unit Included: Yes   Sender Ohm Range: 0-90 ohms   Length (in): 25   Width (in): 17   Height (in): 9   Outlet Fitting Quantity: Two   Outlet Fitting Size: -8 AN   Return Fitting Size: -6 AN   Sump: Yes   Sump Depth (in): 2   Quantity: Sold individually.     Fuel Cell, Plastic, Black, 16 Gallons, 0-90 Ohm Sender, Each
The best value in fuel cells.
Our Pro Street cells have features like seamless polyethylene construction for outstanding impact resistance, available aviation foam filling to prevent fuel slosh and aeration, and a one-way flapper valve vent in the cap, to allow air to displace fuel as it’s being used. Ideal for street use, they include a 0-90 ohm sending unit for use on GM-type fuel level gauges. Other features include flush mount aircraft-type lids, two -8 AN outlets, and a -6 AN vent fitting. And best of all, you get all of this for a very affordable price.
Brand New Fuel Cell and mounting brackets. $150
Brand New SS Braided Lines and Fittings $125
BOTH: $240
http://ubrf.ddetail.com/lafengas/forsale/cell.JPG
http://ubrf.ddetail.com/lafengas/forsale/cell2.JPG
http://ubrf.ddetail.com/lafengas/forsale/cell3.JPG
