I have a Kenwood KAC-7201 800watt 2/1ch Amp mounted to a sealed box
containing 2 10" Infinity Kappa Reference 1030W Subs. The information
for both the Subs and the Amp can be found below. I have had these subs
and amp for little over a month now, and boy do they pound.
Unfortunately due to financial issues I need to part with them. I have the
original box for the Amp. The Sub Box Enclosure is specifically designed
for these subs and will fit into a coupe or hatchback. I am looking for
$500cdn for the Amp, Subs and Box.
::: NEW PRICE $400CDN :::
The 150 watt x 2 channel KAC-7201 2-Channel Power Amplifier has the
power to transform your car stereo into the envy of anyone within
earshot. The bridged power output is 460 watts x 1 channel and the
maximum power output is specified at a whopping 800 watts. The power
MOSFET switching power supply uses two secondary capacitors and a
toroidial noise filter. Features include variable low-pass and switchable
high-pass electronic crossovers, 2-ohm stability, speaker level inputs, a
Quiet Turn-On circuit, and a cast aluminum heat sink with sandblast finish.
GENERAL FEATURES
- Cast Aluminum Heat Sink: with Sandblast Finish
- Power Indicator: Blue Logo Triangle
POWER RATINGS
- Bridged Power Output at 14.4V (1kHz, 0.8% THD): 460 Watts x 1
- Maximum Output Power: 800 Watts
- Power Output at 2 Ohms, at 14.4V (1kHz, 0.8% THD): 230 Watts x 2
- Power Output at 4 Ohms, at 14.4V (20Hz-20kHz, 0.08% THD): 150 Watts x 2
AUDIO FEATURES
- 2 or 1 Channels of Amplification
- Ground Isolation Circuit
- High-Pass Electronic Crossover: 150Hz, 12dB/oct (Switchable)
- Quiet Turn-On
- RCA Audio Inputs: Gold-Plated
- RCA Line Outputs: Gold-Plated
- Speaker Connectors: Screw-Type
- Speaker Level Input Terminals: Plug-Type
- Stereo, Mono, or Tri-Mode Operation
- Variable Low-Pass Electronic Crossover: 50Hz - 200Hz, 18dB per Octave
- Bass Boost: Off/+12dB (90Hz)
POWER SUPPLY FEATURES
- 2-Ohm Stable
- Copper EE-Core Power Transformer
- Noise Supression Filter: Toroidal
- Power Input Terminals: Gold-Plated, Large Screw-Type
- Power MOSFET Switching Power Supply
- Power Supply Fuse: 2 x 30A
- Secondary Capacitors: 2
High-efficiency polypropylene woofer cones - This lightweight and
popular material is used to ensure maximum woofer efficiency. The
benefit is hgh output with modest amplifier power. -
Large-roll rubber surrounds - This material provides optimum cone-edge
suspension and absorbs distortions that may travel up the cone edge,
ensuring clean, tight bass. -
Progressive spider - Each Reference subwoofer uses a progressive
spider, which provides better control at excursion limits than more
commonly used linear spiders. Your benefit to our using a progrssive
spider is reduces distortion at high output levels. -
Vented polepieces - Provides additional cooling of the motor structure is
provided. The subwoofer’s thermal capablities are augmented, thus
increasing power handling. -
Proprietary deep-draw I-beam basket - This allows room for a longer
motor structure, which provides increased bass output. This basket is also
more rigid and has a lower basket resonance.
Specifications
MSRP U.S. $: $109.95 each
Power Handling, RMS: 250 Watts
Power Handling, Peak: 1000 Watts
Sensitivity: 90dB
Frequency Response (±3dB): 25Hz - 250Hz
Mounting Depth: 5-3/4"
Impedance: 4 Ohms
Owner’s Manual:
http://manuals.harman.com/INF/CAR/Owner's%20Manual/REF%20SUB%201030103212301232%20OM%20FINAL.pdf
