fs 240 parts
-set of kvr front pads alot of life left $25
-oem brake rotors all 4 $15
-oem calapers $50
-90 open diff $10
-90 steering wheel $10
-90 rear swaybar with polyurathane mount buchings $15
-beat up 91 bumper $20
-91 engine(no tranny) $100
-hatch with good glass $20
  • hatchback tail lights comp. $20
km on the engine?
any rust on the hatch… and wha color?
engine has about 240ish and the hatch is a custom light blue, and you can see there was rust at one point on it
how old are the swaybar bushings? brand?
they are new, but they are just the 2 bar mount ones
ill come pick them up saturday sometime if you will hold them
ok you so do you want just the bushings then? and you do understand that it is just the two ones with wholes that hold the bar the the body
any problems with the motor?
its missing the p/s and the alt is busted, but it will run goood
the engine has no problems at all? if so ill probly buy it :E
