Making room of a lot of extra parts I have around. So many to take pics of, and boxes of stuff to look thew. I didn’t clean anything up so it might be a little dusty or not the best pics. SO of this stuff isn’t really worth alot, or even shipping cost. But I don’t want to thow out good parts, when there all the beat cars out there. So theirs a MINIMAL OF $15 SHIPPED purcase.
All parts are listed shipped US mainland.
Side cover gasket $20 shipped $10 with other parts. These cost some BS like $50 new. Don’t mess yours up. Good to have a spare.
Dog bones, missing one nut. Little surface rust from sitting in a box. ready for paint. But the bushing are great. $35 shipped
lifter trays $15 shipped $5 with something else, free $50 order
extranal range switch SOLD
crank sensor cover/harness shield $15 shipped $5 with something else
Good clean rocker ~50k miles $30 shipped
stock EGR “penny mod” block over plate. threaded for rear manifolds/headers $5 with something else, free $50 order
clean knock sensors SOLD
clean front cover, painted gun metal. Comes with oil pump inner/out rotor. No pump cover $25 shipped
2 New in box Gm bushing for a alum cradle PN 15240253 $15 shipped
used HD diff cover, no damage $25 shipped. get a spare if you have a LSD.
L67 SC belt idler mount $5 with somthing else. free over $50
lower inspection cover $5 with somthing else. free over $50
New felpro L67 valvecover gaskets, and bolt seals $30 shipped
New napa front contraol arm bushing 267-3504 $5 with somthing else. free over $50
Good working used PS pump, res. nipple in broke off, easy to put yours on $20 shipped
Mint used HD diff cover, with VSS $35shipped
good SC belt 6rib 660 $15 shipped $5 with somthing else
Good L67 ballencer, heavy $35 shipped
New bourg 4t65 HD hight engery band, beliove this is the FWD band $15 shipped $5 with somthing else
LS1 TB to maff bellow SOLD
wheel spacer $15 shipped
good ford 5x8 speakers form a focus, also fit my 2001 E350 truck $25 shipped
Casper O2 sims. $45 one, $80 pair shipped
clean driver claiper 2002 30K miles, bracket, pads,line everything SOLD
Gas cap, $5 with purcuse of somthing else over $10.
fuel line, and Evap line. clean, stock heat wrap $25 shipped
good wheel bearing 02 30K $75 shipped
tracion control box, with cables $30 shipped
LS1 coil $25 shipped
(note this is the gaterback AC belt)
Denso 02, like new $35
gauge cluster ~135K $35 shipped
good cam plate $15 shipped $5 with other stuff free over $50
cam magnets $15 shipped $5 with other stuff free over $50
oil level sensor $15 shipped
Crank sensor $15 shipped
coolant temp sensor $15 shipped
knock sencor SOLD
cam sensor $15 shipped
drilled 180 Tstat $15 shipped $5 with other stuff
good ICM $25 shipped
